How to implement wavelet(uwt) into fpga module
It seems that there is not any wavelet-relative function in fpga module...How to perform uwt on fpga module? Anyone has an idea?
(6,725 Views)
Hi,have you found the wavelet function based on fpga?
(4,275 Views)
Hi, the LabVIEW advanced signal processing toolkit includs wavelet transforms, but it only can be used in host.vi. A book entitled Digital Signal Processing Laboratory: LabVIEW-Based FPGA Implementation, gives details about FPGA implementation applications including wavelet transforms.  On the other hand, if you can get the Xilinx IP core of discrete wavelet transforms for your LabVIEW, you can implement the wavelet transforms into FPGA.
(4,199 Views)
Thank you for your advice. I think the later one is a better choose. Where can i get it ? Do you have any resources. Thank you.
(4,195 Views)
Sorry, I am not sure you can buy it from national instrument
(4,193 Views)
Ok. Thank you.
(4,191 Views)
