How to output a TTL line cRIO-9054 PFI0
Hi all,
We have a 9054 that we need a single TTL signal from to control a switch and I was planning to use the PFI0 line for it. However I can't find an example of how to set it up except as a digital input (here).
It suggests it is possible in the manual but I can't find the right combination of things to allow it in LV. It doesn't appear at the FPGA level or at the DAQ/Scan engine level.
Can anyone point me in the right direction?
Many thanks
Pete
Certified LabVIEW Architect
(1,763 Views)
perhaps this KB makes things a little clearer:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004AfvSAE
Although have a look at this:
https://zone.ni.com/reference/en-XX/help/370466AF-01/mxdevconsid/crio_considersations/
Section "Shared trigger bus"
And finally the block diagram of such a cRIO:
cRIO-9054 Block Diagram - CompactRIO Controller Manual - National Instruments (ni.com)
You have to install DAQmx-support on your cRIO in order to access the PFI0. After that this line should be directly available from the RT-part.
If you need access to this PFI0 from the FPGA you have to set a route between the one of lines between the DAQmx ASIC and the FPGA (the cRIO_Trigx lines). That is done by DAQmx Connect Terminals.vi ; you can now use these lines from the FPGA code to either set or read the PFI0.
Regards, Jens
Kudos are welcome...
(1,727 Views)
Accepted by topic author PWoodward
The bit I was missing was to use Trig0 and to reverse the source and destination on the signal routing.
(1,705 Views)
