How to read frequence from evalution kit
I wan to read signal and i use function generator on rio evalution kit 9636 .I try read but i read always noise .How to read signal from function generator on evalution kit?
(5,015 Views)
Hi osman,
Your question will get more attention from the right people if you post this on the Real-Time Meausurement and Control forum rather than the FieldPoint forum.
I'd be happy to help, but your question is pretty broad. Have you looked at the example programs for the 9636? Are you able to run basic programs on it? If you connect the input line to ground, does the noise go away?
(5,004 Views)
thank you for your answer i will try
(4,964 Views)
