How to save data to SD card when I use cRIO Real-Time (NI-DAQmx) Mode?
Dears,
 I use cRIO -9041 to record temperatue signals by using NI-DAQmx Mode.     I can save the data to USB memoary stick, it works very well.
But now  I want to save the data to SD card, what should I do ?  I change the path ( v:\ ) it does not work .
thanks in advance!
(2,596 Views)
SPEC :
SD Card Slot
SD card support SD and SDHC standards
Supported interface speeds UHS‐I SDR50 and DDR50
Notice:  Full and high speed SD cards are prohibited for use with the cRIO-9041
(2,594 Views)
