How to select Ranges of Analogue channels of sbRIO9636 and multiple channels Read ?
I'm using sbRIO9636 and want to read anaglogue channels, I want to know that how can I select the ranges of analogue channel ? and also I've to read multiple channels with specific time?, How can i calculate conversion and sampling time?
Can anyone guide me ?
Regards
(5,857 Views)
Hello MW_BKT,
You can set the input range of the sbRIO's analog inputs by using the "Voltage Range" property in the FPGA I/O Property node (in the FPGA VI).  Put the FPGA I/O property node on your block diagram and right-click on the top purple part to select the analog input channel you want under Select Item >> FPGA Target >> Connector 0.
The sample rate is dictated by the loop time.  So, if you want a sample rate of 1000 Hz, you would put a 1ms loop timer in the acquision loop.
(5,843 Views)
Thanks alot for your help, I'll check it and let you know.
(5,742 Views)
Thank you very much for the help, I've set the property.
regards
M.Waris
(5,739 Views)
