How to set Differential Mode?
How do you set differential mode on a PCI-6025E board in LabWindows/CVI?
(3,354 Views)
Greetings,
To programmatically set the input mode on your PCI-6025E, you will want to use the AI_Configure function. This function is located in the following location:
Library >> Data Acquisition >> Analog Input >> Single Point
Good luck with your application.
Spencer S.
(3,354 Views)
I have looked into AI_Configure() function. What libraries/headers should I include in my CVI to access this function???
(3,354 Views)
