I am doing data acquisition using the 6024E board, how can I acquire voltages greater than 10V
I am doing data acquisition on MATLAB using the 6024E board, the maximun range I can see is <-10V,-10V>, can I increase this limit to be able to acquire higher voltages
(3,453 Views)
Without knowing the details of the signal you are acquiring (output Z etc), I can only offer an old suggestion.
A voltage divider may be usefull. This will work if your application can tolerate some external resistors.
Ask if you want details.
Ben
(3,453 Views)
The best way is to use some conditionnal product from NI.... Product Like
SCXI which allow you to connect signal up to 1000V....
"WalidJoumaa" a écrit dans le message news:
506500000008000000D2510000-1027480788000@exchange.ni.com...
(3,453 Views)
