I am not getting output signal through output DO card (ni9478) of CRIO9076.
I am using ni9478 DO card to give GATE pulse to inverter. I have made connection as per mentioned in datasheet, but I am not getting output. Please suggest me any solution.
Gaurao A. Dongre
Walchand College of Engineering, Sangli.
Mail: dongre.gaurao1991@gmail.com
(5,053 Views)
Accepted by topic author dongre.gaurao1991
The 9478 does really provide an output.  It either connects the line to ground or doesn't.  It does not output a voltage.  Therefore, you must provide a pull up of some sort.  What kind of pull up did you apply?
(5,046 Views)
I want GATE pulse of 15 v for my inverter so I have given 15 volt supply to vsup pin
Gaurao A. Dongre
(5,029 Views)
