I am not given the option to build my VI
I'm trying to deploy my VI so that it runs on the cRIO-9012 on startup.  After a bit of looking around, it seems that I need to build my top level VI -- something that it doesn't give me the option to do.  I'm also using two modules through the FPGA interace (which have corresponding VIs that it did have me compile).  For these two FPGA VIs, they would compile, if needed, when I hit run; for the top level VI, it simply deploys it from my computer without building.  This may be pretty basic, but I'm just learning here.
I've included a screenshot of my project below, where the 'AI Module' and 'CAN Module' VIs are the FPGA ones that it did let me build, and the 'DataLogLoop' VI is the one that I'm trying to build so it can be deployed.
I have Labview 2015 with both the FPGA and RT modules installed on Windows 10.  Any help is appreciated!
(3,345 Views)
What version of LabVIEW are you using - base, full or professional? Do you have application builder installed?
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
(3,323 Views)
