I have 2 PCI-6110E cards installed in the same pc. Now I encounter some synchronization problem. When I input the same signal to the two cards. There is certain delay between these two cards. Can you give me some help?
(3,557 Views)
Hello;
You didn't mention how you are synchronizing both device, however, the best way to implement a syncrhonized data acquisition in between multiple devices is by the use of the RTSI bus.
You can connect both devices through a RTSI cable, and share the same AI Start Scan clock to clock both analog input tasks.
You also didn't mention what programming language you are using to program the devices, but there are examples on how to synchronize multiple devices both in Labview and NI-DAQ functions.
Hope this helps.
Filipe A.
(3,557 Views)
I want to synch two DAQcard 6115 and 6221with a RTSI ,  can I let the two card share one clock .
(3,015 Views)
