I want a fft ip for fpga, who can tell me what to do this?
Hello!
I found that in some future there should be FPGA FFT example on the IPNet.
Can someone tell me when should I expect that? I need FFT procedure that would be able to give about 2048 points spectrum at 10kHz sampling rate (FFT value every 5 Hz)
(4,822 Views)
Can you tell us more of the application?  Also why is it not possible to do the FFT on the RT controller (cRIO) or PXI (if R series board).  Do you need all the bins, or just specific ones?
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(4,768 Views)
The FPGA IP is now available
http://community.ni.com/examples/fft-in-labview-fpga
Unfortunately there are neither details on how many channels one could simultaneously FFT on either the PXI 7831R or the PXI 7833R nor the expected time needed to execute a 1024/2048 point FFT of 16 bit data
(4,155 Views)
