I want to communicate with a cRio Drivven Throttle unit using Teststand
I have a cRio-9022 with a Drivven throttle controller. I've been exploring around TestStand to try and figure out how to establish communications with the unit, but can't seem to find anything. Does anyone know of an easy way to send commands to the cRio from TestStand?
(5,497 Views)
In order to communicate with your instrument you will have to use one of the adapters in TestStand to call a code module that is interfacing with the hardware. TestStand does not have an explicit way to communicate with the cRIO in the way I think you are looking to do. You could set up an instrument driver that allows you to first get a resource handle, then pass that resource handle into other functions that allow you to perform other auxiliary functions.
Ian M.
(5,486 Views)
