IC 3173 tactile monitor support
i'm designing a IC-3173 based vision gear, that i want to be as simple to use as possible. Therefor i plan to use a tactile monitor as the only UI, to interact with the application front panel. But as i'll choose the NI-RT Linux version (because i need real time capabilities), i wonder if the driver for such monitors exist in this OS...Had anyone already make such a configuration properly work ? Will it work for the image indicator tools (magnifier, ROI tools, etc) ?
Vincent
(3,202 Views)
Hi VdG,
What is the reference of your monitor ?
Thank you
Maxime L
Certified LabVIEW Architect
(3,177 Views)
Hi maxime,
i don't have any reference yet. I saw many tactile monitors with display port input on the web. Do you expect some of them to have linux driver while others haven't ?
Vincent
(3,174 Views)
