IP65 Enclosure for CompactRIO
I'm looking for a suitable enclosure (IP65 rated) for my CompactRIO's. Preferably if the enclosures can be rack-mounted.
(4,484 Views)
This isn't exactly what your looking for but...
You can buy conformal coated cRIO chassis and modules.  You can only get some of the cRIO parts conformal coated, but they may have the modules you are using.
https://www.ni.com/en/support/documentation/supplemental/08/conformal-coating-and-ni-rio-products.ht...
I don't think NI gives an IP rating for the coating but claim it is good for 100% RH condensing.  We take this to mean IPx5 for our company's purposes.
(4,476 Views)
There's no IP65 enclosure, but IP66, http://sine.ni.com/nips/cds/view/p/lang/en/nid/202591,  enclosure is even better.
However, it's not rack mount, you need to use it together with another accessorry, http://sine.ni.com/nips/cds/view/p/lang/en/nid/14221.
(4,465 Views)
Thank you for the replies. Do you guys know the material used for NI's Industrial Enclosure for cRIO? The requirement given to me is that the material has to be aluminum.
(4,449 Views)
This enclosure is made of stell.
You probably contact Hoffman, http://www.hoffmanonline.com/index.aspx?cat_1=1361, to see whether they have a model made of Aluminium.
(4,426 Views)
