Image compression using Sb-RIO 9632 (FPGA-Spartan 3) + VHDL code
Hi Expert,
Currently I doing research in medical imaging, i tried to used VHDL code from Model SIM and ISE to compile in LAbVIEW using CLIP. Until now i didnt know my result regarding the simulation and compile are valid or not. I aspect the FPGA will read the pixel by pixel and send to the GUI. I really appriciate, if any forumers to share their expert and knowlodge regarding my current research.
AbM
(5,815 Views)
My best advise would be to use an image that you know compression result as an input. Then, compare whether the result is correct.
(5,796 Views)
Ok many thanks kateB
(5,792 Views)
