Imaq image control ROI tool button visibility on a RT Target
i'm converting a application (image acquisition and processing), that i used to run on some Windows pc, to a RT application running on a (Linux-RT powered) IC-3173. It takes some time to get the target well configured, but i can now test my application and i discover some issues : UI fonts, path to be adapted and so on...have to work a bit !
But there is one that i don't know what to do about : my main front panel use a IMAQ control to display the image and allow users to interact (zoom, ROI selection, length measurement..). I have selected a set of ROI button, and it's reamining as i want when the application runs on a windows pc. Now, on the IC-3173, i only get the magnifier and and the hand. Is there some tip to select the visible buttons for a RT target, or is it a limitation of IMAQ Vision for RT ?
Vincent
Message 1 of 1
(2,281 Views)
