Implementing a rtexe on cRIO 9064
Using a cRIO 9064 I cannot find the way to implement a RT vi in the cRIO.
It worked perfectly by using the UI vi calling the FPGA vi but I needed an intermediate vi so now I have a RT vi calling the FPGA vi.
The idea is to run the UI and send a flag to the RT vi through a shared variable so that the RT vi can run the FPGA vi. It works by running my RT vi over a distant computer via ethernet and launching my UI vi  by exe.
I tried implementing a rtexe of the RT on the cRIO (/home/lvuser/natinst/bin) but can't find it working.
See image attached
Kevin
Cordialement,
Kevin
Associate developer
(3,068 Views)
Hey Kevin.
Have you set the exe to "Set as Startup"?
Here is a link to some of the things that might cause this issue.
http://digital.ni.com/public.nsf/allkb/52E943F7D6E7C0578625720A001DDF6E
Hope this helped, if not have you tried a simple .vi and set it up?
Best Regards - Baltzer
(3,024 Views)
Thanks for your answer, I finally found the problem.
I implemented my rtexe in the cRio to flash the user led and I got it work with the link you gave me but when I tried to implement a bigger program it couldn't work even with the flashing led loop in front of everything.
I tried to figure it out with a lot of disable diagram structure and it actually appears (after some days) that I had a vi called "entête" with this accent on the "e". I just change the name and I got it work perfectly.
Some little problems can take a lot of time to be managed...
Thanks anyway !
Kevin
Cordialement,
Kevin
Associate developer
(2,988 Views)
