Inconsistent IP
I have cRIO-9014 and it works fine on my computer. However, on my other computer, I faced with inconsistent IP problem. How can fix the problem ?
(4,418 Views)
You likely have a subnet issue.  Are you using fixed IP addresses or DHCP?
(4,413 Views)
Thank you for your interest.
I am using DHPC.
I am confused about difference between DHPC and static IP adress. Which one should I use ?
If static, How can I configure IP4 adress, subnet mask and DNS server?
(4,387 Views)
DHCP depends on a router to assign an IP address.  This avoids address conflicts.  But if you don't have a router, it won't work.  I think there is a default IP address​ in this situation.
But every system I have put together was put on a system network only (not connected to anything outside of the test/control setup) and I used a simple network switch.  Switches tend to not have DHCP capability.  So every system I have done use static IP settings.  You can set the IP through MAX.
(4,380 Views)
Thanks again.
What values should I set for IP configuration ?
IPv4 Adress
Subnet mask
gateway
DNS server
(4,377 Views)
That completely depends on you.  All that really matters is that you are consistent.  A common approach is
Address: 192.168.0.XXX
Subnet: 255.255.255.0
You can leave the gateway and DNS server blank.
(4,375 Views)
