Is LabVIEW 8.6.1 required for RIO 3.3 with Scan Engine support?
I am trying to install RIO 3.3 with support for scan engine with LabVIEW 8.6.
However, after installation, only the minimal set is available for me to download
onto cRIO (Even though the scan interface was selected during the installation of
RIO 3.3). Must I upgrade LabVIEW to 8.6.1 or does it require a different solution?
If I reinstall LabVIEW 8.6.1, will I need to reinstall RIO 3.3?
- Thank you
(3,304 Views)
If you look at the menu, you'll notice that there is a section for 8.6 and 8.6.1.  In your screenshot, the 8.6.1 recommended software sets aren't available, but the 8.6 ones all appear to be working.  If you are using 8.6 and don't want to upgrade, then use an 8.6 recommended software set.
Message Edited by Ruhmann on 01-14-2010 01:01 PM
(3,300 Views)
