Is NI-9142 RIO supports C ANSI Text-Based Code programming?
I hope the question is clear enough from the title...
And I really hope for positive answer...
Tanx for advance (even for negative answer...)
Aviad
Message 1 of 8
(6,012 Views)
Here is some good information on the matter:
'C/C++ Embedded System Design Tools'
http://www.ni.com/white-paper/14623/en/
~ Q ~
Message 2 of 8
(5,849 Views)
Thanks  Queue-tip!
I guess I don't clear my self...
I want to build driver for the instrument that connected to the RIO chassis, e.g: I connect NI-9211 to the NI-9149 chassis and want to  read the outcome temperatures. With labView Its strait forward, Can i do it with C\C++?
Thankes again,
Aviad
Message 3 of 8
(5,837 Views)
You can program the RTOS on a cRIO using C/C++ code (e.g. using the Eclipse). The FPGA on a cRIO must be programmed using LabVIEW FPGA. The following image depicts this information:
The NI-9149 is an expansion chassis meaning that is has an FPGA backplane but no controler runnng an RTOS. Thus, if I am understanding your question correctly, you cannot directly program the 9149 using C/C++.
~ Q ~
Message 4 of 8
(5,817 Views)
Aviad,
The c/c++ api is very similar to the labview interfactace for a RIO device. You can open a reference to the FPGA reference of a remote target with the c/C++ api just as you would with LabVIEW. Once you install the C API for FPGA you should be able to create interact with a FPGA on the 9149 across the network.
LabVIEW FPGA C Interface API
http://www.ni.com/download/fpga-interface-c-api-14.0/4946/en/
Here is an example. if you look at the notes for the nifpga.h you would reference the resource by rio://mysystem/RIO .
https://decibel.ni.com/content/docs/DOC-31772
Kyle Hartley
Senior Embedded Software Engineer
Message 5 of 8
(5,806 Views)
Thanks All!
I am little bit confuse Smiley Frustrated.
At that step of the project, I don't need the FPGA features. I only want to communicate with the modulus that connected to the NI-9149 Chassis, like NI-9211 or NI-9200.
Can I do it without the RIO FPGA?
Thanks for advance,
Aviad
Message 6 of 8
(5,788 Views)
Aviad,
There is not c interface directly to the modules. They are all affixed to the FPGA so at some level the FPGA needs to be programmed to interact with the modules.
What loop rates are you looking for?
Are you doing across network control?
Can you describe your application a little more?
Kyle Hartley
Message 7 of 8
(5,775 Views)
Hi Kyle,
In general description:
My system sample:
  • 12 channels of AD convertors (3 x 4 ports NI-9234) @ 24Khz
  • 12 Analog lines channels (16 ports NI-9220) @ 24 KHz
  • 4 channels of T (NI-9211) @ 1Hz
  • Servo Motion control via NI-9516 - Asynchrony
Thankes for the help,
Aviad
Message 8 of 8
(5,768 Views)
