Is a 9004 RT compatible with a 9111 FPGA?
I have an old cRIO 9004 RT controler with the 8 slot 9102 FPGA attached.  I also have a newer cRIO9012 RT with the 9111 FPGA.  I have a simple project that only requires 2 slots in the chasis, and I was wondering if I can switch the 9111 FPGA to the 9004 RT?
Are they compatible from the 9012 to the 9102 and vice versa for the 9004 to the 9111?  I see the 9004/9102 is listed as legacy on ni.com.
The simple advantage I'm looking at is saving an 8 slot resource for a later, larger project if one comes up, and using this 4 slot one now.  If they are compatible, is there any disadvange I need to be aware of?
(5,291 Views)
AMP12,
Yes, the controllers and chassis can be swapped.  They are compatable with each other.  The only problems you will run into with the older chassis is that it has a smaller FPGA.  If your going to save the chassis for a larger project, you might also want to consider that the larger project will require a larger FPGA as well.  Other than that, there shouldn't be anything you need to worry about.
I hope this helps.
Systems Engineer
SISU
(5,280 Views)
