Is the AT-MIO-16E-2 ISA card compatible with a Pentium III 1GHz with a 133MHz bus?
Is the AT-MIO-16E-2 ISA card compatible with a Pentium III 1GHz with a 133MHz bus? The system has an ISA slot available but I'm afraid the bus speed is too fast for this old card. Do I need to buy a new PCI card to work in this system?
(3,222 Views)
Hello;
As long as your machine has a ISA slot and that the NI-DAQ driver is properly installed on it, you shouldn't have any problems with it.
Regards
Filipe A.
(3,222 Views)
