Keep losing contact to my real time target(cRIO), what to do?
Whenever I stop any .VI I get a commnunication error  and then lose connection to the crio
Message 11 of 13
(1,381 Views)
What do you mean when you said a previously running VI opens up?  Does the same VI open regardless of which code you're running?  Another thing to try is to significantly lengthen the time of your timed loop.  Does it still lose connection when you do this?
Message 12 of 13
(1,356 Views)
Hey, problem fixed finally!!! 😃
It was either altering the universitys firewall or installing labview 10 that did the trick
Message 13 of 13
(1,247 Views)
