Keithley DAQ6510 real time measurements
I have a problem and can not figure out how to make it work. I am using labview and the example labview code provided by Keithley for the DAQ6510. I have a back 7703 slot. I am trying to read multiple voltages through multiple channels in real time. The problem I have is I need to take about 5 measurements a second for up to 6 channels. When I use the example code I can read multiple channels but only taking about 1 measurement a second. Does anyone know how to take readings in real time? The example code I have been using is attached. I have also tried 2 other example codes from Keithley but none will allow me to take 5 measurements a second. I have attached the other code as well.
(3,049 Views)
I'm measuring 4WR in multiple channels and same as your case, i need to have the data in real time.
I have no clue how to get 5~10 data in a second.
If you found solution about this, can you share that with me?
(1,968 Views)
