Killing an application running on RT
Hi
Am using an PXI -8186 embedded controller with PharLap ETS RTOS, i have downloaded an application on to the RT startup directory. I want to deleted the application as i dont need it, but as it automatically starts running when pxi boots up i am unable to delete it. How can i Kill the application and delete it from startup? The rtos does not have a promt, so i can kill the task or look in to directory.
I have to use only Ftp. can any one please help.
thanx
Arun
(3,141 Views)
Hello!
On your 8186 there is a disable start up VI switch. On page 2-12 of the manual you will be able to find the location of this switch. Just incase I have pasted the link to the manual below.
http://www.ni.com/pdf/manuals/370747c.pdf
After you disable the start VI you will be able to remove it. Hope this helps. Let me know if I can give you anymore assistance.
Allan S.
(3,129 Views)
