LabVIEW FPGA module crashes
Hi:
I'm having trouble with Labview 2011 FPGA module; i just updated to Ni developer suite 2012, i was using Labview 8.6; i have a vi that compiled and worked fine in labview 8.6; i rewroted it from scratch in labview 2011 sp1, but when i try to compile it, it crashes after it starts synthesizing.
A popup appears:
xtclsh.exe has stopped working.
The summary says:
LabVIEW FPGA:  An internal software error in the LabVIEW FPGA Module has occurred.  Please contact National Instruments technical support at ni.com/support.
The Details says:
LabVIEW:  The path is empty or relative. You must use an absolute path.
Error 1430 occurred at Read from Binary File in niFpgaCompileWorker_CreateBitfile.vi->niFpgaCompileWorker_JobComplete.vi->niFpgaCompile_Worker.vi:1
Possible reason(s):
<Not A Path>
I have no idea why this is happening. I'm in a hurry, so i need it to work as soon as possible.
Please help me!
Fernando Martinez
Electronic Engineer
(5,035 Views)
From the error log, you have some file path issues on a Read from Binary File.  I don't have LV2011 but if you can post a screenshot showing your path generation and the binary read we might see something.
--Using LV8.2, 8.6, 2009, 2012--
(5,000 Views)
