LabView RT TCP/IP max send buffer size
I need to establish a TCP/IP streaming communication against a C++ written application.
I have noticed that a sample application I have made when running on a Windows machine can produce packets as large as 1638400 bytes (which is the size i need to transsmit in every send action) while the same exact application, running on my target cRIO-9025 will break the packets to size 72400 bytes.
Is there a limit to the packets size sent from the cRIO and if not what could cous this behaviour?
Thaks,
Yuval,
LabTunes
(5,320 Views)
Hi Yuval,
How are you monitoring the packet size?
Is it possible to send in your code, or a similar code that reproduced the issue, so that we would be able to reproduce the issue here?
<Brian Aswege | Applications Engineering | National Instruments>
(5,300 Views)
HI Brian,
Since I wrote that post a day another working day has passed and i have learned some new things.
I have downloaded a TCP/IP spy program and monitored the traffic. It seem that TCP/IP sends a constant packets of 1500 bytes (obviously, why couldn't I think of that at first place) the only difference is at the receiving side. Labview TCP/IP read function has, I presume, a transparent buffer used in "buffered mode". In that case I get big packets while when using "immediate mode" the TCP/IP read function works the same way as the C++ program does.
Anyway, when I compare the packets received from the same VI while running on the RT target to those while running on a PC, the second seem to be able to create larger & constant packets (or pseudo packets) at the C++ receiving end then those from the RT. In any case the receiving program will have to accumulate those packets to a FIFO in order to create an internal constant data stream.
So as it seems to be my problem is no longer a problem, but at least I have learned something new.
Thanks for your help,
Yuval
(5,287 Views)
