Labview FPGA compile worker 2016 for Linux using CENTOS 6.6 (RHEL 6.6 - 64 bit)
I have a sofar perfect FPGA compile setup, using a linux server with Labview FPGA compile worker 2016. Until now I was able to compile all  NI FPGA devices I use faster than on my own PC, also offloading my PC CPU.
However, I cannot compile for the cRIO-9066, but the Windows Labview FPGA compile worker 2016 can.
https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio... says Vivado 2015.4 should be enough.
Have attached what the 2 compile workers show. Windows has a red arrow, and that is the worker is uses.
Linux have same capability, but fails compilation with "LabVIEW FPGA: Some of the compilation steps were not executed."
Any inputs would be helpful 🙂 Tanks
Message 1 of 1
(1,977 Views)
