Labview RT Ethercat Configuration
I have IF1032ETH Micro-Epsilon Ethercat module and i am trying to communicate with Labview RT in Ethercat configuration but unable to load ESI (xml file) file in project and getting message "The software can not import device profile". Same file working with TwinCat- 3 software system and able to scan I/o channels. Please find attached file for more information and suggest solution for Labview RT environment.
(1,275 Views)
Hey buddy,
I saw a very similar case to yours solved by NI "Import Third-Party EtherCAT Devices into the Scan Engine and EtherCAT Devices" and the solution is in the following link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFI2SAM&l=en-US
If this link didn't solve your problem you can reply to this post by a screenshot of the error so I can have closer look!
(1,187 Views)
