Labview failed to load library blockdataapi.* "BlockgetIOReferenceByModule:C on
After project copy and re-editting I came in a lot of problems. Labview Hangs,MAX crio error, no communication to my cRIO-9074 etc.
I formated the disk and re-installed the Labview software and now at least MAX has no errors, IP adr. ok.
Deploying my application VI gives (as before) ;Labview failed to load library blockdataapi.* "BlockgetIOReferenceByModule:C on RT target device"
VI does not run.
How can I correct this problem?
Greetings,Frank
(3,535 Views)
Accepted by topic author Engelenfve
Hi Frank,
It looks like your VI is using the NI Scan Engine Advanced I/O Access API (http://zone.ni.com/devzone/cda/tut/p/id/8071)
This component is not installed by default, so you need to add it since you formatted your cRIO.
The excerpt below if from the document linked above with installation instructions:
"Support for the Advance I/O Access API must be installed on the target from Measurement & Automation Explorer (MAX). Expand the target under Remote Devices, right-click on Softwareand select Add/Remove Software. Select Custom software installation and install the component called NI Scan Engine Advanced I/O Access 1.0."
 Hope this helps!
Kurt
Message Edited by jkurtw on 03-25-2009 08:45 AM
(3,530 Views)
