Linux cRIO Remote Panel Configuration File Location
Where are the Remote Panel Configuration Files located on the Linux RT Targets?
Also, if the SSL configuration of the remote panel configuration is located in a different configuration file, where are those located?
What I'm trying to do:
Enable Remote Panel Server
Set HTTP Port to non-default
Enable Remote Font Panels
Enable SSL
Setup non-default SSL Port
I need to do this programmatically, preferably by editing the configuration files on the target instead of using the LabVIEW project.
Thank you!
Message 1 of 1
(2,766 Views)
