Load cell data acquiring using 9205 module
Dear Sir,
1. As the load cell output is in mV and the 9205 module has the capability to acquire data of +/- 200mV , I have thought to acquire directly from load cell. So, in this regard let me know what are the precautions should be taken so that I can acquire the data without any errors or noise.
Thanks and Regards
Giridhar
(3,746 Views)
I am assuming the Load cell you are using is made with strain gauges mounted to the cell. I would suggest you refer to this tutorial which explains the measurement techniques as well the hardware requiered for the Signal Conditioning like Bridge excitation, amplification, offset nulling. Also you can refer to this example.
Hope that helps!
Kindly mark it as a solution if your query is solved!
Shreyas Hebbare
Shreyas Technologies
India
(3,734 Views)
