Loading PHARBOOTSYS error
I am using Labview 8.2 with ETS Desktop PC. When I try to boot the PC through USB utility, it gives error message "Loading PHARBOOTSYS Error".
The same PC was used as RT Target earlier with Labview Real Time 8.2 (So, no compatibility issue is there). Few days back, an attempt was made to install LabView Real Time 8.5 on the same PC. The HDD and USB are reformatted after that in FAT32.
What could be the cause of this error?
Rashmi
(3,361 Views)
Hello Rashmi,
Was there any change made to the softwares installed on your system after which it starting popping up the error?
Regards
Akshat Jain
(3,314 Views)
