Low-level communication through either serial or Ethernet port on the FPGA
Good evening,
I would like to create a FPGA program that communicates with a non-labview program. To do so, I would like to send and receive data through either the serial or ethernet ports on the FPGA. I am having trouble finding how to access these resources on a low level with the limited VI's present in the FPGA functions list. I am using a cRIO 9022 device and Labview 2010.
Any advice or resources would be appreciated.
Thanks you,
Clay Upton
(3,803 Views)
Clay,
Since these built-in ports are located on the cRIO controller, not the FPGA backplane, you can access them through the cRIO RT Target.  To do this, you will need to install NI-VISA and NI-Serial on the cRIO.  They should be able to be accessed just like any other port on a normal computer (using VISA, TCP/IP, UDL, etc.)
Good luck!
Drew T.
Camber Ridge, LLC.
(3,791 Views)
