MAX error, exceprion in CmxProviderWrapper::Finalize
MAX error on startup, has happenened multiple times, any ideas how to fix?
Message 1 of 12
(7,251 Views)
When exactly do you receive the error message?
Message 2 of 12
(7,234 Views)
I would suggest you download the last MAX version available at the following link:
http://joule.ni.com/nidu/cds/view/p/id/3560/lang/es
Message 3 of 12
(7,233 Views)
Hi
I have now updated to MAX 5.3.3, and also updated all other Labview components using update manager. The problem persists. It usually happens on starting MAX, although not every time. It seems to relate to a problem configuring cRIO device. Sometimes I get an error when configuring my cRIO, where it cannot save changes because connection is lost. On the next startup of MAX I would then see this error.
Message 4 of 12
(7,219 Views)
The following link give some information about how you can fix the niVISAui.mxx Error
http://www.how-to-fix-errors.com/errors/fix-niVISAui.mxx-error-niVISAui.mxx-error-fix.html
Message 5 of 12
(7,199 Views)
Hi Marand
That site looks dodgy. Also not sure niVISAui.mxx error is applicable here...?
Message 6 of 12
(7,195 Views)
M7,
I am getting the same error and also having difficultly communicating with and loading software to my cRIO device.  I am concerned that my almost new cRIO may have failed,  but before I give up on it I wanted to investigate this MAX error.  I attached a zip file with the referenced log & dmp files.
Did you find a fix?
James
MAX niVISAui.mxx Error
Tech Advisor - Automation
LabVIEW 5.0 - 2020
Message 7 of 12
(7,108 Views)
Hi James
I have not found a fix, and am not able to use my cRIO with labview 2012. (mine is an old cRIO, and I also thought it had failed until I tried another one and got the same problems).
My work around has been to use another computer with labview 8.6.1 and the cRIO is working fine.
What version of Labview are you using?
Message 8 of 12
(7,003 Views)
M7,
I uninstalled LV2012 and went back to using LV2011, but still have the newer MAX 5.3.3 installed.
My MAX errors persist, but was able to get my cRIO (9014) working, for a while.
However, I am currently battling problems caused by changes to our Network Security Policy.
I am hoping that NI's next release arrives soon and corrects many of these issues and LV2012 bugs.
James
LabVIEW 5.0 - 2020
Message 9 of 12
(6,997 Views)
It sounds like your Measurement & Automation Explorer (MAX) database may have become corrupted. Please see the following documentation for procedures on how to remove the database corruption:
What is the Process For Removing MAX Database Corruption?
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
Regards
Message 10 of 12
(6,988 Views)
