MAX says my PXI-7833R is a PXI-7831R
I have a PXI-7833R and I noticed that in MAX it is listed as a PXI-7831R.  Would this affect the resources that the compiler is optimizing for?  The reason I'm asking is that I have a VI that I am working on for the FPGA and I have reached a point that I have run out of slices.  I don't believe that my VI is complicated enough to have used all 3 million gates on the PXI 7833R.
Thank,
Message 1 of 8
(5,997 Views)
Hello BruceBarnes,
That is a strange behavior with your PXI-7833R device.
What version on LabVIEW, Operating System, and NI-RIO do you have?
As an additional note, this may require an uninstall/reinstall of the NI-RIO driver (if you have not already attempted this) as it is possible that a driver corruption may have occurred. But before doing this, we can try removing the device in Device Manager.
  1. Press [Windows]+[Break (the last key on the top right-hand side of a standard keyboard)] to bring up the System Properties dialog box.
  2. Select the Hardware tab and click the Device Manager button.
  3. In Device Manager, go to NI-RIO Devices and click on the expand icon (plus)
  4. To remove an unused device driver, right-click the icon and select Uninstall.
  5. Try restarting your machine and see if the PXI-7833R is recognized instead of the PXI-7831R
Juan Galindo
Message 2 of 8
(5,898 Views)
Juan,
I found the problem late yesterday.  I decided to pull the PXI-7833R from the chassis to see if the board had any identifying markings on it.  It does, the board is a PXI-7831R!  So somehow our 7833R was built with the 7831 board.  I don't know if it happened during the original manufacturing, or when we sent it back for AO repair.  Now I will talk to those who were involved in the purchase and subsequent repair to find out when this happened and try to get this issue resolved.
Bruce
Message 3 of 8
(5,870 Views)
Thanks for informing me about the status of your issue.
Hope you can talk to the necessary people to get this issue resolved.
Juan Galindo
Message 4 of 8
(5,851 Views)
Bruce,
Can you please give us the serial number of that device?
Jeff Tipps
Product Support Engineer - R Series
Message 5 of 8
(5,714 Views)
Bruce,
Were you able to talk to those involed in the purchase of this card? Also, do you have the serial number of this product?
Juan Galindo
Message 6 of 8
(5,634 Views)
Juan,
The serial number for my FPGA module is 00E477F1.  I did talk to the people that were involved with the purchase and later repair of this unit.  It turns out that a PXI-7831R module was originally ordered.  For some reason our module has a PXI-7833R front panel installed on a PXI-7831R.  Since I began working on this project later I naturally assumed that since the front panel said it was a 7833R and that there must be a problem with the installation or MAX.  But we have what we paid for and it is working quite well.
Bruce Barnes
Message 7 of 8
(5,620 Views)
I am glad to hear that Bruce.
Thank you for that note.
Juan Galindo
Message 8 of 8
(5,618 Views)
