MAXPOS 50/5 and CompactRIO
Hi everyone,
I'm having a problem with running MAXPOS 50/5 and compactrio combination.
The ethercat is not working. I cannot put the maxpos in "Operational Mode". The error i get is hex 0x8005442c.
Thank you.
(2,174 Views)
Hi NikolaiM,
I looks like that error relates to the interaction between master and slave.
To check what steps you've gone through, have you followed the following to add the ESI file?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9CqSAK&l=en-GB
To rule out the installed software being an issue, have you reformatted the NI CompactRIO and reinstalled the software?
James P
(2,120 Views)
