MIgrating from CRIO 9073 to CRIO 9074
I'm moving an application from a CRIO 9073 to CRIO 9074.  The application runs on the scan engine with one vi on the FPGA to run the serial I/O module.  On the new machine am having trouble with the "Open FPGA VI Reference" Node pointing to the VI running on the FPGA:  The "Open FPGA VI Reference" returns the error "-61017 LabVIEW FPGA:  You must recompile the VI for the selected target."
I have recompiled (repeatedely) the vi for the new CRIO 9074 target.
Details:  Labview 2010, FPGA 10.0.0
In the "Configure Open FPGA VI Reference"  the target is the vi "FPGA target 2\4-port serial.vi" , the option "bind FPGA host reference to type definition" is selected, and the path to  "C:\Documents ... \FPGA\901x DMA FPGA Reference.ctl" is specified.
I've attached the scan engine VI that tries to get the reference while running "Init"
Any suggestions?
(5,357 Views)
Hi PESobol,
Do you still see this issue if you point to the bitfile rather than the VI?  Also, there's a related issue documented here that's worth looking at.  Try unbinding that type definition or creating a new copy and see if this resolves the issue.
(5,335 Views)
