Maximum power requirements of USRP B200 mini
I would like to know how much power usrp B200 mini needs in terms of watt while transmitting LTE signals . basically I am using the usrp as a base station which is running SRSLTE .I will really appreciate any of your help! Thanks in advance!
(2,761 Views)
Hi ,
The maximum input power for the B200/B210/B200mini/B205mini is 0 dBm.
Timing Reference Input
B200mini/B200mini-i/B205mini-i
  • 1-PPS or 10 MHz input
1-PPS
  • Maximum: -5V / +5V
  • Minimum: 0V / +2.5V
10 MHz
  • Maximum: 0V / +5V
  • Minimum: 0V / +1.8V
OR
  • +10dBm ~ +27dBm
B200/B210
1-PPS
  • Maximum: 5V
10 MHz
  • Maximum: 15dBm (3.5Vpp into 50 ohms)
More information you can find here
(2,693 Views)
