Measuring over 11Kohm Resistor with cRIO system, is it possible ?
Hi everyone
I am using NI cRIO-9054 in my test bench, one of the tests that i supposed to do is measuring resistors.
The product has resistors bigger than 11kohm, I need to check their values and verify they are correct.
My problem is that I can't find a resistor measuring module that I can plug it in the cRIO slots which is capable to measure more than 11kohm, the nearest module that I found is NI-9219 and the biggest value is 10,5kohm.
In this link, all modules suggested by the configurator.
https://ohm.ni.com/advisors/crio/pages/common/compare2.xhtml?conversationContext=3
Does anyone have an idea?
Thank you.
(1,274 Views)
I have the same problem
I did not find the suitable module with compactrio to measure the 11 k resistor
(1,208 Views)
