Measuring with 9202 via FPGA gives always zero
Hi there,
I`m working on my first realtime/FPGA project in LabVIEW. Most of the things are working well, but I`ve a problem:
I installed 3 9202 for measuring voltages. All of them returning in my code exactly "0" with and without some (voltage)source attached to them.
Here is the configuration I`m using:
I made a reduced VI just for figuring out what is wrong:
But it`s the same thing as in my real project and I don`t know what`s the problem might be. I`ll tried different configs of the 9209 (samperate, filter ...) but nothing worked.
When I`m using NI MAX (scan engine) I get the right voltage on each channel.
Does anyone has an idea what I`m doing wrong?
Thanks!
(977 Views)
Accepted by topic author mtursch
You need to write TRUE to the start channel to start the acquisition. Always refer to the shipping example to get started.
<LabVIEW>\examples\CompactRIO\Module Specific\NI 9202\NI 9202 Getting Started\NI 9202 Getting Started (FPGA).vi
https://tmesystems.net/
(937 Views)
Thanks! I guess it is something stupid... 🙄
(910 Views)
