Monitor to sbRIO does not work
Hi, I am not able to get any connection between a sbRIO-9628 and a DELL Monitor when connecting via The USB-C displayport. Just black screen. Reboot does not help. I am using a passive cable USB-C to DP. I am aware an active adapter is needed if changing to HDMI or DVI but can not understand why it should be needed if monitor has DP connector. Any clues to a solution? Do I need to connect keyboard as well? Regards, Dan
Message 1 of 1
(1,071 Views)
