Motion control: UMI 7764 has no signal when MAX doing a motion
I would like to ask for support on the question as stated in title.
Background:
I have connect a 7342 card to PC with UMI 7764.  After I install all the software correctly, I run the MAX (measurement & automation explorer) with right configuration.  UMI7764 has power supplied.
Problem:
I then setup the MAX to run the motor in 1-D interative.  After press start, the normal outcome be the Step & DIR having signal output.  But, it has not.  Surely, the servo motor connected (through the motor drive) does not move.
So,  can you help me to solve the problems
Thanks a lot.
James
(3,117 Views)
Good Morning James,
I am assuming that this is a duplicate post from the following:
http://forums.ni.com/ni/board/message?board.id=240&message.id=3857
If I am incorrect, please post back and I will do my best to answer any questions that you may have.
Respectfully,
(3,103 Views)
