NI 1483 with camera Baumer HXC13
Yea, I guess the problem is strictly with labview programming on FPGA, as camera is giving fine image with another software after pluging it to the PC.
Message 11 of 17
(2,436 Views)
Ok that is good to know. So we will concentrate on the code. Did you change anything else in the code (e.g. the configuration)?
Anna Vogl
Certified LabVIEW Developer
Message 12 of 17
(2,434 Views)
I have changed CL Data To Pixels.vi to 2-Tap 10-bit configuration, as my camera is in this mode. I did it according to those steps: http://digital.ni.com/public.nsf/allkb/EA1727D8D620B81F8625797B0072257C. I also changed buffer size, as I was getting errors with DMA write timeout. 2.png
Nothing more changed I guess.
Message 13 of 17
(2,432 Views)
So you changed it back from 8tap 8 bit as you described first?
Anna Vogl
Message 14 of 17
(2,421 Views)
Yes, because I thought it will be easier to change only one parameter, but it didn't help me actually.
Message 15 of 17
(2,416 Views)
Ok, now I am pretty much sure that my black window is caused because of the 'Data' from Invoke Metod DMA FIFO. I realised that the array which is coming out of the 'Data' is full of zeros (black colour). What can cause this problem of zeros?
Message 16 of 17
(2,395 Views)
The Zeros can have multiple reasons. First you need to check the configuration of the camera (in the example: configure camera link). Is everything set in a way that its is supported by your camera?
Also check the serial communication (serial interface). Is everything correct there?
Anna Vogl
Message 17 of 17
(2,355 Views)
