NI-9068 Deploy Exectable Script
I have a (working) project for my NI-9068 cRIO that I'm developing on Windows.  As part of my build specification, I'm uploading some linux scripts to the 9068.  What I want is to have those scripts flagged as exectuable (chmod +x) on the 9068 when they're deployed from LabVIEW.  Is there a way I can set the file up in windows so that when it's uploaded that the bits are set?  Alternatively, is there a way for me to fire some ssh commands to the 9068 when I click "deploy" or "run as startup" from the build specification?
thanks in advance.
(4,377 Views)
Managing these bits in files exchanged with Windows is always a pain (not just on cRIO targets but on any mixed Linux/Windows environment). Usually either all of your files from Windows get +x (even if they aren't executable) or none of them (even if they are) on Linux.
Can you fix the permissions as an early step of your deployed VI? See http://zone.ni.com/reference/en-XX/help/371361H-01/glang/setting_permissions/ for what I have in mind.
You may get a good audience for this question at https://decibel.ni.com/content/groups/ni-linux-real-time if you repost this there.
(4,368 Views)
Hi there,
According to your post I am seeing that you want to install a start up scripts on the cRio. if so it would be a good idea to take a look into this file
Also here is some document that could be useful for you
Regards
(4,348 Views)
