NI-9132 Real Time Deployment Hangup
Hello, I am trying to deploy a project file to my NI-9132 running Linux and Labview 2019. In the project file, I can deploy and run most files/VI's, except, for some reason, it hangs up on one file. The Support VI's folder in the project file will start to hang up, and progress no further than the pictures below. I found it would hang up on either the enqueue message (single), or the Error Handler Vi's. It has enough memory, and CPU usage when investigating with the NI distributed system manager. I used the NI QMH template, as I was attempting to learn more about the QMH, but would like to try and deploy this VI and see how well it works. I have also tried on another computer to see if that was the issue, and I received the same result. If someone has any leads on how to fix this issue, please let me know! Thanks!
Message 1 of 1
(977 Views)
