NI 9147 chassis
I want to make the following configuration: a CPU " NI cRIO-9056 " + an extension " NI 9147 Ethernet RIO " + 10 modules " NI 9220 " for a TCP communication: how to connect the CPU with the extension?
On the other side, is it possible to make a configuration of acquisition with extensions (for example " NI 9149 Ethernet RIO " + " NI 9147 Ethernet RIO " + modules " NI 9220 ") without passing by a Compact RIO ?
Thank you in advance
(1,070 Views)
It is possible to connect to NI-9147/9 chassis directly from a Windows host PC. See Setup Guide for Ethernet RIO Expansion Chassis.
https://tmesystems.net/
(1,056 Views)
