NI 9211 / CRIO 9013 thermocouple measurement ?
Hi , I'm a newbies with thermocouple , but I try to read values of two thermocouple (type S and K )  on my 9211 module.
I was thinking that has analog module 9211 send me voltage and I will use a VI to convert it into Temperature.
But I am wrong the module give me temperature on the A0 A1 channels !
So I try to use VI from the labview example (C:\Program Files\National Instruments\LabVIEW 2009\examples\CompactRIO\Module Specific\NI 9211) But I can't use this one because I don't have th FPGA licence so I don't have acces to autozero channel and cjc chanel !
How can set the NI 9211 to give me the right temp with the thermocouple model ? or how can I convert the actual temp send byx the odule into the right one ( type S or K) ?
Thanks for your help
(4,842 Views)
Accepted by topic author cnm_ch
auto answered :
It simple (too simple maybe :D) to configure thermocouple I need to press property on the module (not on the channel i have tried only this one)
and you can configure type / and unit for the result !
Hate myself ...
(4,841 Views)
