NI-9211 connection
Is there a way to connect the NI-9211 to your computer (via USB) without using a chassis?
(3,370 Views)
Hi SonOfCabe,
You can use the 9171 single slot chassis to connect to your computer using USB:
https://www.ni.com/en-us/shop/model/cdaq-9171.html
(3,317 Views)
@rleonard3 wrote:
Hi SonOfCabe,
That's exactly what I'm trying to AVOID! I'm looking for a simple cable solution, if it is possible.
(3,312 Views)
The 9171 will be the simplest form factor to connect your card to your computer. The 9211 doesn't have the inherit ability to connect via USB.
(3,308 Views)
