NI 9220
<p><p>hi all,<p><p><br><p><p>I have just bought NI 9220 c-series daq. It has 16 channels and capable of simultaneous data sampling.Just wondering where can i find programming examples to use it on acquiring data simultaneously. I am using it with compactrio. The chassis i have is NI 9113 and NI 9025 controller.<p><p><br><p>Thanks.
(8,351 Views)
Hi xssdd,
You can use the example finder to get examples in LabVIEW and you can search with regard the hardware you have.
Here is a KB on how you can do that
Nathan
National Instruments UK & Ireland
(8,329 Views)
Hi, All the examples, which I have found are for cDAQ. I need examples for cRIO and FPGA mode. Anyway to find example for cRIO with all the NI 9220 operating in simultaneous sampling mode? Thank you.
(8,321 Views)
Greetings;
Would you happen to have the RIO Driver installed already? If so, what version of LabVIEW and the driver are you using?
I took a quick look into the Example Finder (LabVIEW 2012 SP1) and I see the NI 9220 User-Controlled IO Sampling project that demonstrates how to use the module in a cRIO.
Cordially;
Simon P.
(8,315 Views)
Hi xssdd,
Simon-p is right, once you have the correct software and you follow the steps you should get an Example finder which looks like this -
This will give you cRIO specific examples.
Nathan
(8,305 Views)
